Automations with Less Annoying CRM 12/2025
Automations can be used to create shortcuts for steps you take all the time as part of your workflow, like adding tasks, updating a pipeline, or saving notes. Define the steps of the automation once, then apply those steps manually or have them run automatically whenever you change a contact status or a form gets submitted.
Getting started
Creating automations
Learn how to create automations in LACRM.
Read more >>
Running automations
Learn how to run automations that you’ve created.
Read more >>
More info
Editing automations
Learn how to edit automations you’ve already created.
Read more >>
Curated
